914_teener
Aug 20 2013, 01:08 PM
All,
Have finished a re-hab of the rear swing arm bushings.
They are the harder polyurethane and I installed four zerks to assure I have no squeaking or binding.
What lubricant grease should I use that won't break down the poly compound?
Thanks in Advance
Eric_Shea
Aug 20 2013, 03:19 PM
Factory says... glycerine paste:
Eric_Shea
Aug 20 2013, 04:20 PM
Sorry... my reading skills are bad these days:
You should be able to use Daystar KU11004 Lubrathane Poly Lube.
https://www.google.com/shopping/product/161...ved=0CFgQ8wIwAA
914_teener
Aug 20 2013, 05:29 PM
Thank you Mr. Shea
brant
Aug 20 2013, 06:35 PM
You might want to consider cutting channel into the bushing. It gives the grease somewhere to go and spree Round. Otherwise it doesn't disperse well
euro911
Dec 30 2013, 02:24 AM
Brant, are you talking a channel like a key-way, longitudinally?
Dave_Darling
Dec 30 2013, 08:01 PM
I believe the typical procedure would be to cut a spiral groove on the ID.
--DD
914_teener
Dec 30 2013, 11:41 PM
I don't know Dave....
I just made sure that the hole penetrated the bushing so the the grease could lubricate the shaft. I installed 1 zerk per bushing and when I hit it with the grease gun Pascal's law had no problem surrounding the shaft with grease.
I notion-ed that since the shaft needed a smooth surface to bear on, I didn't want to deform any of that surface, IMHO.
