Allan
Dec 9 2004, 06:19 PM
I am putting my 2.0 back together and so far everything is looking really good. Got all the cooling tin painted, case cleaned and align bored, heads rebuilt, new euro P/C's, smog equip. stripped, etc. As I am getting ready to put it all back together I found that I don't like the look of that big structure used for the air intake. Just too damn big and covers all of the new shiny bits. Is there an after market set up that is not too expensive? I saw one on ebay awhile back that basically looked like a piece of 2-3 inch pvc elbow with a K&N filter clamped to the end of it. Any body know how to make something like that? Any help or advise is greatly appreciated. Thanks.
McMark
Dec 9 2004, 06:21 PM
With a 2.0 intake being straight up, can't you just get a K&N that fits right onto the throttle body?
Allan
Dec 9 2004, 06:25 PM
I will still need a place to hook up a hose or 2 and would have to put some type of riser between the filter and throttle body. I don't know how much room there is between the throttle body and rain tray.
eeyore
Dec 9 2004, 06:42 PM
Allan
Dec 9 2004, 06:46 PM
I would like to go with something that simple but I'm sure I'll need at least 2 places to hook up hoses wont I? I think one for the charcoal cannister and the crank case vent?
McMark
Dec 9 2004, 06:54 PM
Drill them into the top or put a small PCV spacer below with fittings in it.
dlo914
Dec 9 2004, 07:18 PM
spent $40 for the K&n Filter & $10 on clamps and PVC piping....
JoeSharpOld
Dec 9 2004, 07:19 PM
Alan: Check out a thread titled She's Running. Pictures. By newdeal 2. It uses a PVC T and 2 filters with lots of space for hoses. I liked enough to look into it for my car.
Joe
dlo914
Dec 9 2004, 07:21 PM
here's what the PO had installed....
Allan
Dec 9 2004, 07:49 PM
I think I have found the answer!! Please refer to newdeal2's post on his recent runner. And thanks Joe.
Tom73
Dec 9 2004, 08:32 PM
Maltese Falcon
Dec 9 2004, 08:47 PM
Allan, you can make this from pvc, a steel u-bend. The pvc is referred to as "The ghetto ram air" style - as it is called on many other boards I read ! If you are not running a rain lid, watch out for those downpours- cone filters will suck in water.
If you need any short bends, PM me and I'll send you a few ( 2"/ 2.5" or 3") . Ubends run about $20 ea. but you can have the rems for freebies
Allan
Dec 9 2004, 08:48 PM
Yes, just like that but a c-note seems really steep for the parts involved in making it.
mattillac
Dec 9 2004, 10:02 PM
i made one of those things for my '75 2.0. i think i need to try a different tubing length or something, cuz the damn things resonates with a nice low whistle/hum noise at low rpms.
"huuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuummmmm!"
TheCabinetmaker
Dec 9 2004, 10:21 PM
Dumped my factory air filter years ago.
K&N air filter=$40.00
PVC pipe and fitings=$4.00
A little imagination=priceless
$20.00 for a ubend?
$100.00 for the setup?
newdeal2
Dec 9 2004, 11:32 PM
Hey guys...the T fitting with barbed fittings for the hoses [4] and 2 K&N filters. Also need some nice hose clamps and a rubber insert at the throttle body to make up the difference in dimension on the pvc pipe.
I said in my thread "She's Running" I will be posting pictures with details in a few days so be patient.It makes no funky noise except sometimes when you shut her down and then it's a cool air , hiss, suck sort of deal
Bruce Allert
Dec 9 2004, 11:40 PM
QUOTE(McMark @ Dec 9 2004, 05:21 PM)
I tried it and it works without the rain tray... I can't run w/o the tray
.....b
Rhodes71/914
Dec 10 2004, 12:57 AM
I have been thinking about this since this thread a little over a month ago.
Air IntakeI too am in the process of putting my 2.0 back together and like the idea of getting the coolest air to the intake. Check out
Demick's 4 hp for $4 I think I am going to do some variation of this.
Sean
DJsRepS
Dec 10 2004, 06:41 AM
I used my stock 1.7 rubber elbow thing to the orignal oil bath without cutting anything.
DJsRepS
Dec 10 2004, 06:45 AM
The yellow lines in the above pic are my black gas lines covered with yellow heat shrink. I colored my vacuume lines. Colors availble Blue Red Yellow White Clear and Black.
