siverson
Aug 20 2013, 10:44 PM
I haven't seen this style nut before, and McMaster Carr doesn't even carry it. They are for use in the linkage of ITBs. Note there is a hole on the screw.
Does that flat side go on first? How exactly do I wire this hole?
Anyone seen these before?
-Steve
Click to view attachmentClick to view attachmentClick to view attachment
Elliot Cannon
Aug 20 2013, 10:50 PM
The hole in the bolt is for a "cotter" key to be used with a castlated(sp) nut. The nut you have is a lock nut used extensively in aircraft. You wouldn't normally use a cotter key with this type of nut. The flat side goes on first.
siverson
Aug 20 2013, 11:24 PM
Thanks, got it. That makes sense to me. I'll just order some slotted nuts. I know what to do with those...
http://www.mcmaster.com/#slotted-nuts/=o5manm-Steve
76-914
Aug 21 2013, 08:24 AM
If that is an AN3- or AN4- bolt I have the castellated nuts and cotter pins. I'm in Temecula if you need a few.
jimkelly
Aug 21 2013, 08:51 AM
yup - ovaled lock nut - nice ; )
