QUOTE(wndsnd @ Sep 2 2013, 08:24 AM)
I got and installed the two wire brake light switch on the new master cylinder.
Thank you 914Sixer..
When the ignition switch is turned on, my break lights are on. If I disconnect the wires at the switch, they stay on. It they short together, the red light in the multi guage flashes. I am not questioning the switch, it did this with the single spade switch as well.
Any guesses what's up?
I think the wires you are using is the brake pressure switch wire . Others will clarify shortly, I am sure.
The switch is fine bit you will have to locate the right wire. Do you have any wires connected to the brake light switch under the brake pedal?
