I have a 19mm Master Cylinder on my car but I believe that the mechanic reused the sensor switch from the leaking 17mm MC that it replaced. The warning light has been blinking. The light was not blinking with the small leak that I had with the 17mm. I'm hoping that the sensor switch just needs to be reset.
How do I reset the 17mm?
Does the 17mm switch work with the 19mm MC?
Thanks as always!
