LotusJoe
Aug 26 2013, 02:02 PM
I seem to recall someone was selling a replacement bracket that either bolted on or riveted?? Or am I dreaming?
Eric_Shea
Aug 26 2013, 02:04 PM
Weld it...
dlee6204
JawjaPorsche
Aug 26 2013, 02:05 PM
76-914
Aug 26 2013, 02:09 PM
Pete @ Restoration/Design. Which welds? If bolt welds came loose replace it. If bracket welds came loose I'd still order a new one but I'd look at the wall it is welded to pretty carefully.
LotusJoe
Aug 26 2013, 02:14 PM
Thank you, that's the kit I was looking for, however at $80.00 I think I'll just weld it back.
green914
Aug 26 2013, 02:58 PM
QUOTE(LotusJoe @ Aug 26 2013, 01:14 PM)
weld it back.
pt_700
Aug 26 2013, 04:03 PM
a local muffler shop welded a used replacement bracket in for me.
of more difficulty was re-setting the torsion bars...
i think i invented a few new curse words...
Bartlett 914
Weld it on. There is a lot of pressure on this part. The problem is the lubrication for the hinge bolt. There is no easy way to lubricate it. They have a tendency to seize which rotates the bracket breaking it off. Same for the front trunk. Grease it when installing
SLITS
Aug 26 2013, 04:23 PM
Which is exactly why I ditch the torsion bar setup and go to a gas shock set up to relieve the pressure the torsion bars put on the bracket.
BKLA
Aug 26 2013, 10:22 PM
I have an unused jwest hinge kit I'll sell for $50.00 shipped.
I got rid of the torson spring, installed the gas struts and welded the stock hinge point back on. But I had the engine out and rear suspension off to make the repair much more simplifed.
