QUOTE(partwerks @ Aug 28 2013, 02:19 AM)
Is it hard to install?
That's next on my list.
At a stop, does it go into gear easily all the time?
It's easy to install, but tricky to adjust. I had my mechanic/friend do it b/c he had adjusted them before. Also you should replace all the bushings, and make sure clutch is properly adjusted. Mine shifts great now. Much more precise and shifts feel solid. Used to have a lot of slop (probably bushings) and very mushy. Hope that helps,
Tom
