HalfMoon
Aug 26 2013, 09:58 PM
I'm sure the anwser is simple but I've yet to figure it out.
Momo wheel and horn button.
Mike Bellis
Aug 26 2013, 10:11 PM
Just stop turning and you'll be fine...
The wire coming from the ring triggers the horn when grounded. You either have an intermittent short or an intermittent open depending on how you wired it.
moldygreg
Aug 26 2013, 10:33 PM
Doing this from memory.
Is the horn contact ring well 'nested' within the momo adapter?
I don't think the momo adapter and horn contact screw holes always line up perfectly; you may need to chip away some of the plastic horn contact ring with a small blade to allow the holes to line up and 'snug into' the adapter. I think some people have actually drilled new holes in their contact ring.
Did you over-torque the steering wheel? Should be 40lbs.
eg914
Aug 26 2013, 10:45 PM
The brass on the contact ring can wear, break, and make contact when you turn. Pull the steering wheel and check the contact ring.
Sleepin
Aug 27 2013, 08:09 AM
Make sure the wire doesn't have a crack in the insulation.
r_towle
Aug 27 2013, 12:08 PM
remove fuse.
If you need to honk, its too late, or your just being an asshole.
rich
