x-faktory
Aug 27 2013, 09:20 AM
Where is Sweet Pea now? After searching for a while and looking at many lesser cars, I could not get this fine 914 out of my mind. I contacted Joel, we struck a deal and Melisa and I jumped on a plane for San diego to pick up Sweet Pea. We met with Joel & Shannon, inspected the 914, had a great dinner with new friends, exchanged the paperwork and headed back to the hotel. Next morning, Joel & Shannon delivered our new 914 to the hotel and we headed north.
This 914 runs very strong. Some front end vibrations at 70-75, but otherwise...solid and gets lots of attention wherever it goes.
I am a happy camper!
I've attached a couple pix. Joel & Shannon in tears...Melisa and I smiling durng the hand off. And then................a pic of our first stop.
Can you guess where Sweet Pea is...or at least was yesterday?
regards,
Al
PS: Joel & Shannon are the bomb.
McMark
Aug 27 2013, 09:22 AM
NORD
Aug 27 2013, 09:26 AM
What part of the PNW do you live at? Nice car.
x-faktory
Aug 27 2013, 09:44 AM
nord,
I'm in mount Vernon.............not too far from you.
regards,
al
CptTripps
Aug 27 2013, 10:48 AM
Cool story!
Glad to see happy new 914 owers.
Congrats!
KELTY360
Aug 27 2013, 11:38 AM
Isn't that Jerry Mahoney's old car? Looks like it's come full circle back to the PNW. Great car!
Drums66
Aug 27 2013, 11:43 AM
....Good to hear a positive "experience"
good fortune with her in the future!
(WELCOME)
x-faktory
Aug 27 2013, 06:07 PM
QUOTE(KELTY360 @ Aug 27 2013, 10:38 AM)
Yes, I believe that is correct. Coming back home.
regards,
Al
messix
Aug 27 2013, 06:09 PM
if that's Jerry's old car then that is one very nice clean car.
I saw it over at kelty's house one day and drooled all over it!
x-faktory
Aug 27 2013, 06:13 PM
Where is Sweet pea today?....at least as of last night and this morning
regards,
Al
sixnotfour
Aug 27 2013, 06:15 PM
Sweet..!!!!needs a six..
x-faktory
Aug 30 2013, 08:57 PM
After my San Diego to Santa Barbara to Los Gatos to Redding to Eugene, OR to Mount vernon, Wa..............my new 914 is safe & sound in my garage.
3d914
Aug 30 2013, 09:16 PM
Nice looking car!
Enjoy!
messix
Aug 30 2013, 09:39 PM
the picture really don't do the car justice!
Jerry is a body guy that does very nice work and that car is a great example of his skill!
scott_in_nh
Aug 31 2013, 09:27 AM
What size wheels and tires?
Springs, shocks, bars?
I love the way she sits - beautiful car!
x-faktory
Aug 31 2013, 10:04 AM
Here's the specs...from the P.O.
regards,
Al
1970 914 Willow Green
Suspension brakes wheel specs:
Front suspension and brakes: 911 T
Front suspension torsion bars: 18mm 911 type, stock red
Front suspension sway bar: 914/4 type 15mm stock
Front suspension bushings: stock rubber
Front suspension strut inserts: Bilstein sport yellow new
Rear suspension springs: 100 lbs Weltmeister SP100 black
Rear suspension shocks: Bilstein sport yellow new
Rear suspension sway bar: none
Rear suspension bushings: stock rubber
Wheels: Fuchs 16 x 6 polished lip, satin black center
Tires: BF Goodrich 205/ 50 R16
Master cylinder: ATE 19mm, new
Brake lines: ATE rubber, new
Engine and drive train specs
Pistons: 96mm flat top 8.5 to 1 compression
Crank shaft: 2.0 Porsche 71mm
Connecting rods: 2.0 Porsche
Cam shaft: webcam XXX custom grind
Cylinder heads: 2.0 Porsche 3 stud, rebuilt
Induction: New dual Weber 40 IDF carburetors, center pull linkage heim joints, Teflon lined Terry cable
Ignition: Bosch mechanical advance distributor with electronic trigger, Bosch blue coil BERU spark plug wires
Exhaust: SSI stainless steel heat exchangers, Bursch merged tuned 4-2-2-1 collector
Engine case: 1.5 quart low profile external sump
Fuel pump: front mounted Carter rotary type powered by factory fuel power circuit
Fuel lines: BMW 8mm CA ethanol fuel rating
Oil: Brad Penn 20-50
Transaxle: rebuilt 901 side shift conversion, new shift linkage and bushings, 90wt hypoid Valvoline VR-1
Rear transaxle mounts: upgraded 911 sport mounts
Starter motor: upgraded IMI Hi Torque gear driven with high current external solenoid
Interior specs
Morph interior panels
914rubber.com seals by Mark whitesel
pedal cluster by Bruce Stone
Steering wheel: 3 spoke Dino
Floor mats: Lloyds black with green 914 monogram
Seats: black with custom cloth center inserts, adjustable passenger seat
Seat belts: new retractable type
Entertainment: new stereo and Baupunkt speakers with IPOD and MP3 player
Door panels: custom 911 RS type
Pedal cluster: rebuilt, zinc plated, powder coated, silica-bronze bushing kit
Exterior, paint and body specs
Color: original L63k Willow green monochrome paint scheme
Side marker delete, antenna delete
Fresh weather strips rubber, door seals, bumper tops, body gaskets
New windshield
Daiberl
Aug 31 2013, 10:12 AM
Beautiful car, Jerry Mahoney did a fantastic job, great that the car is back in the PNW!
- Juergen
green914
Aug 31 2013, 10:44 AM
Looks great!
jimkelly
Aug 31 2013, 10:57 AM
great example of a beautiful narrow body
Harpo
Aug 31 2013, 11:00 AM
Very nice car you got there
David
PanelBilly
Aug 31 2013, 08:40 PM
So when are you inviting us over to meet the new family member (and you too)?
