Jon H.
Aug 27 2013, 10:30 PM
I have 1973 2.0l with djet and it will flood and not start. I bought the motor from a friend of mine and I heard it run before I bought it .
Now this thing will not run long enough so i can figure out what is going on. I have already done two oil changes to get ride of the fuel in the oil. This is starting to get expensive.
I have checked the CHTS it is good. The MPS coil values are within spec and the MPS also holds vacuum, some what. Fuel pressure is 30-29 psi while cranking.
I cranked the engine for 15s and the Fuel injectors fuel volume measured between 4 and 6 tsp's per injector(is this good)??. I checked the valve adjustment, all is good. I unplugged the cold start valve and capped it off so i know its not that. If i pull the injector plugs it will start to kick, run a bit and burn off the excess fuel and then not run(because the unplugged injector).
I'm sure it's an ignition problem.
How can I check my timing and dwell with a motor that wont run? it will run after waiting 12 hours then it floods and dies.
This is not an engine that is running rich but an engine that won't run because of a rich condition. I raise my fists in frustration!!
I'm sure this is an ignition problem and not a DJet issue.
I have tried to figure this out since May but have been unsuccessful.
Regards'
Jon
JamesM
Aug 27 2013, 10:42 PM
1. MPS holding vacuum "somewhat" might not be good enough.
2. Did you check the CHT resistance at the ECU connector? infinite resistance (broken wire) will cause a super rich condition that makes it pretty much impossible to start without holding open the throttle.
if none of the injectors are leaking and you are super rich, these are your prime suspects, swap out the MPS for a known good one and see if it helps.
mankowski
Aug 27 2013, 11:00 PM
From Brad Anders' website:
Injector flow rate data (courtesy of Roland Kunz):
Yellow (1.7L) - 265 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift
Green (2.0L) - 380 cc/min @ 2.0 Bar, 3V, 0.15 mm ± 0.05 mm lift
So, your output is well within this rate, quite a bit lower, in fact.
The MPS sounds bad.
MPS Vacuum leaks: Depending on the extent of the leak, the car can run
slightly rich to very rich across the entire load range.
You can make an approximate setting of your ignition timing statically. Here is a good description, which although written for the 911 is largely the same for our 914s. Once you get it close enough statically, it should run well enough for you to set timing dynamically. Of course, your valves need to be correctly adjusted first, and you didn't mention them, but I am guessing you think they have not changed substantially since you ran the motor previously.
Do you have the correct CHTS for the motor (with correctly functioning resistor, MPS and ECU)? What is the resistance shown by your test to be 'good'? Finally, have you cleaned and checked the functioning of the trigger points in the distributor housing?
Check these additional things and report back on what you find. Hang in there!
mankowski
Aug 27 2013, 11:04 PM
Here is the reference to the static timing description that I left out of the last post.
http://www.pelicanparts.com/techarticles/9...atic_timing.htmAlso, should have been Paul Anders.
- Eric
QUOTE(mankowski @ Aug 27 2013, 10:00 PM)
The MPS sounds bad.
Mblizzard
Aug 27 2013, 11:15 PM
Sorry to suggest things you have likely all ready done but we just got to the party.
Working with you on it being a timing issue. What did you change since you heard it run?
Assuming you did a basic tune up and you did not remove the dizzy from the car.
Go through the process of finding TDC and verifying it is at TDC by confirming the piston is at the top in #1 cylinder. Remuneration the timing marks on the impeller make 2 revs to one of the dizzy.
At TDC, the rotor should be pointing to #1 which should be toward the rear of the car. If it is not then you are not at TDC or your wires are incorrect. Since you have verified TDC by the presence of the piston at the top of #1 your next step is to arrange the plug wires on the cap in the correct firing order starting with #1 lining up with the location of the rotor at TDC. The car should run if this is correct. If it wants to start and is still flooding, pull the fuse on the fuel pump and see it will start using starting fluid.
If you did remove the dizzy you will also want to confirm that you did not move the drive gear. Look for the thread referring to 12 degrees.
This should get you the information to either keep chasing a timing problem or move on to the FI system.
Sorry if I am only suggesting things you have done already.
Jon H.
Aug 28 2013, 05:39 AM
Thanks for all the replies.
1. The CHTS is the correct one. I didn't check the wire to the ECU though.
2. I re-did the valves last night just to be sure.
3. I will try and get a good MPS today.
4. The fuel pressure holds pressure quite well, no leaky injectors.
5. It has ran after sitting all night but after about a minute it will flood.
6. Can you put the distributer in wrong as mentioned above? I did remove it when I re-sealed the engine. I didn't remove or loosen the lock collar though.
I will be gone away from the house until Sunday so then I'll try the items mentioned above.
Regards'
Jon
Jon H.
Aug 28 2013, 06:37 AM
The kids are still sleeping so I checked continuity from the CHTS to the ECU and the MPS to the ECU, all is good. Fuel system still has 10 psi, which is surprising.
Jon
r_towle
Aug 28 2013, 06:45 AM
did you remove the fuel supply line from the cold start injector?
They have been known to get stuck in the open position, so if you reroute the fuel line around the cold start injector, you guarantee to get it out of the loop.
You will need either a new fuel line, or a male male connector to do this.
Unplugging the electrics from the cold start injector will not shut it off.
If you have already done this and its still flooding, its most likely the MPS.
Rich
sean_v8_914
Aug 28 2013, 07:42 AM
yeah. what Rich said
Dave_Darling
Aug 28 2013, 08:07 AM
QUOTE(mankowski @ Aug 27 2013, 10:04 PM)
He goes by "Brad Anders".
I had similar symptoms once that turned out to be a problem with the ECU. In fact, I even wound up hydro-locking the motor with fuel, once!! It took me a long time to track that one down, since the ECUs are generally quite robust.
--DD
r_towle
Aug 28 2013, 11:00 AM
QUOTE(Dave_Darling @ Aug 28 2013, 10:07 AM)
--DD
Interesting to hear of another ECU going south.
Seems the soldering process changed in the early 80's to a worse process.
Some sort of flow process that made more cold joints than not.
84 911 ECU needed to be redone
91 BMW light ECU needed to be redone.
Never had to do either a 914 or Volvo p1800 ECU's from the 70's
Rich
toadman
Aug 28 2013, 01:05 PM
QUOTE(Dave_Darling @ Aug 28 2013, 06:07 AM)
--DD
This happened to me, too, except that I didn't have the hydro-locking. I flooded the engine a few times and was stranded by the side of the road a few times before I solved this one. I was troubleshooting this problem off and on for several months before I accidentally brushed up against the ECU with my arm and felt a hot spot on the metal case. I thought "that's not good" so I changed the ECU and everything was fine.
tumamilhem
Aug 28 2013, 01:06 PM
I am having the same issues you are right now. Unfortunately, I'm no mechanic, so it's been difficult for me to figure this out. Reading the suggestions on your post is even more confusing to me, but probably relevant to my issue.
I've received lots of good suggestions on my post, same issues as yours. Maybe they will be of assistance to you as well. Good luck! Here's the link:
http://www.914world.com/bbs2/index.php?act...=2&t=216237
Jon H.
Aug 29 2013, 06:40 AM
QUOTE(tumamilhem @ Aug 28 2013, 11:06 AM)
http://www.914world.com/bbs2/index.php?act...=2&t=216237Isn't this painful? I do have a bit of mechanical skill but that doesn't make this easier. I have been following your thread and trying some of the suggestions that have been made. Hopefully we will get this figured out. I'm sure we will!
Jon
Jon H.
Aug 29 2013, 06:59 AM
I had mike at
Mikes 914's double check my mps, he said it was good and wouldn't be the issue. I now know that the chts is the wrong one. The motor and all associated electronics are from MY 73' so my chts should be reading 1300 ohms vice the 2500 or so that it is currently reading (Is that 1300 reading at the usual 68 degrees?) I should have the chts ending in #017 and not #003. This is still surprising since the motor ran before removal.
Now since these are NLA I guess I need to install a resistor? Will this work as well as trying to source the correct chts?
Jon
Java2570
Aug 29 2013, 07:33 AM
How is your injection wiring harness? If the engine ran prior to you putting it in your car and now you are having these flooding issues, I would think it's a harness issue.
Even if your MPS tests good, a bad wire in your harness could tell it otherwise.
I ended up sending my harness to Jeff Bowlsby and he found it was not fixable.
Jeff makes great replacement harnesses and it made a huge difference in how my car ran. Or you could also try swapping MPS & ECU with known good units to see if it makes a difference but it really sounds like wiring is causing your components to ask for too much fuel.
Jon H.
Aug 29 2013, 08:12 AM
QUOTE(Java2570 @ Aug 29 2013, 05:33 AM)
I have tested the the mps, chts and injection portions of the harness, I unplugged the cold start fuel line and capped it off. I will check the rest of the harness when I get home on Sunday. I will also try grounding the chts to the engine. I have know access to other 2.0l FI parts here in ottawa.
Thanks for the suggestions.
Jon
Bartlett 914
Aug 29 2013, 09:44 AM
QUOTE(Jon H. @ Aug 29 2013, 07:59 AM)
I had mike at
Jon
Make sure you have the correct components. Brad Anders site shows the correct combination. There was a big change between 73 and 74. The MPS, ECU and the CHT must be matched. 73 used a balast resistor (resistor in series with the CHT). in 74, this was removed and the ECU is different. Make sure the CHT is actually connected to the ECU. This wire can be broken. You can also wire in a pot in place of the CHT. Near 100 ohms when warm. Higher resistance = richer condition across the full operating range. The pot on top of the ECU is for the idle circuit mixture.
JamesM
Aug 29 2013, 09:49 AM
QUOTE(Jon H. @ Aug 29 2013, 04:59 AM)
I had mike at
Jon
The higher resistance on the CHT would cause you to go rich but I don't know if it would cause it to go so rich it wont run. As you have found the 73 CHT is near impossible to find, your best bet is to get a 74 ECU and MPS(or just adjust your current MPS to match).
Do not get discouraged, these systems are not very complex. If you have already confirmed that the 5th injector is not leaking (which it sounds like from your rail holding pressure that it is not) then there is only a limited number of things it could be.
Also, just because your MPS holds a vacuum does not mean its good. Unless you have taken it and ran it in another car without issue, I would not count it out as a suspect. I saw this exact thing on a 73 1.7 a few weeks ago, car was running great then all of a sudden it was super rich and wouldn't idle. Checked the MPS and leaked down faster then it should but not fast enough that you would think it was a problem, everything else checked out though so I let him borrow one of my spares and sure enough, car would idle again.
Jon H.
Aug 29 2013, 10:27 AM
QUOTE(JamesM @ Aug 29 2013, 07:49 AM)
I had mike at
Jon
I'll try and eliminate the chts first then try and source another ecu and mps. That does seem like a good solution. There is no one near me to swap out components so it makes this more difficult to diagnose.
Jon
Jon H.
Aug 29 2013, 10:37 AM
QUOTE(Bartlett 914 @ Aug 29 2013, 07:44 AM)
I had mike at
Jon
I do have the list of compatible components, I'll double check that mine match. I did test the wiring harness from the ecu to the cht.
Jon
ConeDodger
Aug 29 2013, 10:43 AM
Is the wire from your CHT sensor broken or disconnected?
Jon H.
Aug 29 2013, 11:23 AM
QUOTE(ConeDodger @ Aug 29 2013, 08:43 AM)
Nope, it all checks out. I wish it was something as simple as that.
Jon
914_teener
Aug 29 2013, 01:14 PM
I agree with the suggestions about the MPS and can relate about what happened to me that was particularly frustrating:
My car had similar symptoms....sometimes flooding....sometimes running.
I went to Harbor Freight and got the Actron vacuum gauge just to test it.....statically it tested out fine....HOWEVER...I noticed that it would leak down slowly just barely within the time limits on the Anders site.
Over the course of about a month.....it got worse. This time I tested it again and "no go". Decided on a new one.
I took the original apart and discovered it had split. I surmised that the diaphragm had split slightly and then progressed to the extent later that is just wouldn't hold vacuum at all.
So when you say somebody else tested it.....make sure the criteria of the test. It must hold the vacuum over time.
Secondly after replacing the MPS it would run....but still running uber rich...by then....it was WTF.....I just happened to have a spare ECU I had picked up....swapped it out...all has been good for 3 years now.
So be prepared for several things (meaning the FI components)....and that given confidence in your own self that the solution will be found, given that you need to be methodical in your approach. There is nothing like a good running FI system...in my opinion.
Some of the best advice I have received...and confidence...has been from folks here.
You have to be in the frame of mind to receive it. What you choose to do with it is up to you.
Jon H.
Aug 29 2013, 03:52 PM
QUOTE(914_teener @ Aug 29 2013, 11:14 AM)
I am fairly committed to get this thing fixed just because put on carbs will be like a cop out. I wish I had a bunch of spare FI parts that I could swap around but I don't. I'm also holding out on buying used new stuff since it can get costly if it the new parts I replace don't solve the problem.
Thanks for the encouraging words.
Jon
Spoke
Aug 29 2013, 05:08 PM
You mentioned that the CHT measured 2500 ohms instead of 1300 ohms.
This will cause the engine to run rich. Not sure if this is your entire issue but it isn't right.
Go to Radio Shack or equivalent and get a 2500 ohm resistor (any power level) and connect it from the CHT connector to ground. When paralleled with the 2500 ohm CHT the 2 will measure 1/2 that value or 1250 ohms.
Try that and see if it runs.
Jon H.
Aug 29 2013, 06:01 PM
QUOTE(Spoke @ Aug 29 2013, 03:08 PM)
Or what about a 1200 ohm one in series?
Jon
r_towle
Aug 29 2013, 06:04 PM
get a 0-3k variable potentiometer.
Its a volume control switch at Radio shack.
Use that to set the motor up...inline with the CHT.
Once you are done and the car runs right, measure the resistance across the POT, and replace it with the exact resistor you need.
Way faster than guessing.
Rich
Spoke
Aug 29 2013, 06:49 PM
QUOTE(Jon H. @ Aug 29 2013, 08:01 PM)
Jon
Do you mean one 1200 ohm resistor instead of the CHT sensor? Yes.
If you add a resistor to the CHT, then you want it in parallel with the CHT, not in series. Resistors in series add; resistors in parallel reduce the resistance. You want to reduce the resistance.
Series resistance: Rtotal = R1 + R2
Parallel resistance: Rtotal = R1 x R2 / (R1 + R2)
Jon H.
Aug 29 2013, 08:49 PM
QUOTE(Spoke @ Aug 29 2013, 04:49 PM)
Jon
Right! totally didn't think that out. Of course it adds resistance when in series. I did take electrical in high school, and I got an A!
tumamilhem
Aug 30 2013, 08:04 AM
QUOTE(r_towle @ Aug 29 2013, 08:04 PM)
Rich
I think I need to follow your suggestion with my car, but I don't understand anything electrical.
Jon H.
Sep 1 2013, 09:42 PM
Well I solved the flooding issue
I had two wires break off the connector a while back and I soldered them back on but they were put back into the wrong spots (although I marked them
). But now that I have that fixed I have no injector pulse (I used a node light to check that). I did read that a faulty MPS would cause this. I do have a line on some ECU's and MPS's that are local (Cool914) and I will give them a try and see if it fixes this problem. I'm sure its not the dist. since it worked when I left town and now it doesn't since I fixed the MPS wires. I also tested the whole wiring harness for continuity and tested the Ohms for the MPS at the ECU. I did drop the MPS on the shop floor tonight?
One question though, would the mismatched wires cause the MPS to become inoperable? The readings across the primary and secondary coil are still both within spec.
Regards'
Jon
914_teener
Sep 2 2013, 04:56 PM
Not sure but if this is the case but it is possible to short out a portion of the ECU....so I am not sure which wires you crossed....MPS? Which ones?
Try to get a spare ECU for your motor and see if that does it.
914_teener
Sep 2 2013, 04:57 PM
.....oh and if you have a problem with wires breaking off.....you need a new harness.
I didn't mess around trying to solve problems that kept reappearing. I called Bowlsby and got a new harness.
r_towle
Sep 2 2013, 05:01 PM
put a noid light on the wires from the distributor for the fuel injection timing....see if that signal is working properly.
Rich
Jon H.
Sep 2 2013, 09:30 PM
It is now fixed
I assumed that since the two outside wires on the MPS went to the appropriate places then the two inside ones should be fine(since the plug can be turned around and still work). Well I was wrong, the two inside ones should also be wired as per the OEM wiring diagram.
Regards'
Jon
