QUOTE(r_towle @ Aug 29 2013, 03:50 PM)
The 914 MPS has an extra diaphragm that allows the base setting to float based upon air pressure and vacuum.
This makes it way more sensitive than the other available MPS units that are from the same Era, same Djet system.
Vw, Volvo, Mercedes (to name a few) all used Djet in the early 70's
Try this (not poking, just speaking from real live experience with a modern o2 sensor as a guide)
Find the MPS unit from a VW 411.
Slits had a few, ask if he still does.
He knows the part number also if nothing else...I cant remember it and the car is not here anymore.
I have a box of MPS units from different cars of the era...I was searching for one that would work in this situation and I found it.
That MPS works for larger motors and slightly more overlapped camshafts.
It also has a similar fuel ramp, so its will idle better.
That unit does not have the lower diaphragm like the 914 MPS does.
ITs also externally adjustable with an allen wrench, and you WILL need to set it to your motor and altitude.
Setting it can be done with an AFM setup.
I use one that stuff up into the tailpipe far enough to heat it up, then I run the wiring over the trunk and up into the passenger compartment.
From there, its a drive and tune run around town on different roads, speeds, loads etc.
Its not a huge amount of tuning and you are seeking to get it so it wont lean out...and not run so rich at idle that you have a sucky idle.
Takes about 30 minutes to get it perfect...or as perfect as you can get within the limitations of Djet.
Now, once you get it close to perfect, you may want to look into a multi spark system, or even a crank fire system for ignition.
You can run more advance on the larger motors with higher CR...but only a few degrees and you need to control it much more than what the factory distributor can do.
Rich
Thanks a lot Rich,
I drilled the plug and made a cute miniature set of tools so I can adjust it in the car. I seem to be robbing Peter to pay Paul though, moving flat spots around. I suspect my idle problem is not due to the MPS and I am going to hunt around for stray air tomorrow.
I am thinking the second diaphragm (provided new by one of our generous sponsors) is there to provide a second enrichment curve, but the way it is adjusted is hard for me to understand. You move the stop so it changes the point where that curve kicks in - sort of - actually it appears that you only really control how much of the pulse lengthening is going to happen on one curve vs the other. In practice I am getting a bit lost.
I can adjust through a hole in the cap that still allows the cap to serve as a stop. I have an easy time with the little screw basically adjusting rich/lean and the cap adjusting where WOT is. The part I am having trouble with is what in practice to do with the outer hex adjuster. Any hints would help. Is it normal to drive around, stopping to adjust as you go?
I have to say this has been a humbling experience and a very interesting challenge. I have enjoyed the support of the board.
