QUOTE(r_towle @ Aug 29 2013, 03:54 PM)
What type of carbs are you using?
What fuel pump?
What fuel pressure regulator?
rich
I have a 32/36 weber carb. The fuel pump is a Mr gasket 42s micro electric pump. I am not using a pressure regulator. The car didn't have one so I didn't put one on. I'm thinking that may be an issue as the carb can only handle 3.5 psi. The pump doesn't specify it's output. Any suggestions on a regulator?
