I bought my 73 914 1.7 in April. Car runs great, compression is in spec. After rebuilding the carbs and adjusting the idle I started getting the oil pressure light at idle once the car was good and warm. I even turned up the idle speed to stop this but then I was idling at 1200rpm. I am running Valvoline VR1 20W-50.
After researching low oil pressure here, I installed a VDO gauge and sender using the "remote mount" grease gun hose and a tee so I could also use the idiot light sender. I was hoping to see about 10 psi per 1000rpm but the gauge confirmed that the pressure was low. After warming up the engine I was seeing about 15 psi at 3000rpm and almost zero at idle (and the pressure light was coming on just as it had been.)
So digging in a bit more, I replaced the oil cooler seals because they were leaking (just some drips on the garage floor, nothing major). I also took out the primary pressure relief valve just for giggles, cleaned it and put it back. Now I have everything back together and I go out for a drive... Low and behold I have oil pressure!
I'm running 40 psi while driving and it drops down to just above 10psi at idle. Couldn't believe my eyes so I drove it more to make sure I was at operating temp. Still no problem, good on the gauge and no oil light. I was able to set the idle back to 800 rpm and still no problem.
What would have changed? Would a leaking cooler seal cause this? Glad to have pressure again but always curious about root cause.
