QUOTE(nsyr @ Aug 30 2013, 05:47 PM)
Got it.
Checked this out too:
http://autorefrigerants.com/envirofaq.htm...
Q: Is Enviro-Safe ™ Refrigerant compatible with other refrigerants?
A: This answer is actually twofold. Yes, it is compatible with all other refrigerants and will not harm the system. In the United States though, it is currently not legal to mix different types of refrigerants together. Intentionally mixing Enviro-Safe™ Refrigerant with another refrigerant unlike itself is not in accordance with the USEPA.
Q: Is Enviro-Safe ™ Refrigerant compatible with all refrigerant oils?
A: Yes, Enviro-Safe™ is totally compatible with all refrigerant oil available today. It can be used with Mineral, Ester and PAG oils without incompatibility.
Q: Can I legally mix Enviro-Safe ™ Refrigerant with R-12 or HFC-134a?
A: The United Sates Environmental Agency (EPA) prohibits the mixing of certain types of refrigerant that are not already "pre-approved mixes". Although mechanically there is no risk of incompatibility, there is legislation that prohibits such acts. (Although it will certainly work well as a replacement for either R-12 or 134a, if your car is still an R-12 unit it would first have to be defined as a 134a or other type of non-ozone-depleting unit before you could legally install it).
Q: Is it legal to use Enviro-Safe ™ Refrigerant in automotive applications?
A: Yes, when used as a HFC-134a replacement there is no need to change any hoses, oil, o-rings or compressors. Enviro-Safe™ recommends you contact the U.S.E.P.A. or refer to the U.S.E.P.A. website for information concerning your individual application.
Q: Is Enviro-Safe ™ Refrigerant approved by the USEPA?
A: No. Enviro-Safe™ Refrigerant has not been submitted to replace R-12 in automotive applications. The USEPA Clean Air Act regulates the replacement of ozone depleting products (such as R-12) with non-ozone depleting products (i.e. HFC-134a). The USEPA does not and cannot regulate non-ozone depleting substances (i.e. Enviro-Safe™ Refrigerant) to replace other non-ozone depleting substances (HFC-134a). Therefore, Enviro-Safe™ Refrigerant does not require “approval” to be used or sold as a HFC-134a replacement.
Q: Is Enviro-Safe ™ Refrigerant environmentally safe?
A: Absolutely! Enviro-Safe™ Refrigerants are organic, non-ozone depleting, non-toxic compounds. These types of refrigerants are endorsed by the GreenPeace organization and are in full compliance with the UN Montreal Protocol.
