QUOTE(Dave_Darling @ Aug 30 2013, 08:18 PM)
The sender for the oil pressure "idiot" light is on top of the motor, next to the distributor. It's kinda buried in there, under a hole in the engine tin. There may be a rubber plug over the hole.
The sender for the oil temp gauge is in the "taco plate" on the bottom of the motor. That's the round sump plate that is held onto the crankcase by two bolts.
--DD
DD, thank you for pointing out the location of the senders. I think I was looking right at the oil pressure sender and didn't even know it. Tomorrow, I'll try again.
