QUOTE(Luke M @ Aug 31 2013, 02:15 PM)
QUOTE(kg6dxn @ Aug 31 2013, 10:40 AM)
I've never heard of 110mm.
I have 100mm
I have 108mm
I used to have 94mm
My 108mm 930 CV's use 10mm bolts. My 108mm 911 CV's use 10mm bolts. My 100mm 944 CV's use 8mm bolts.
I just checked a few threads on the bird board. Looks like the 110 mm flange is used with a 108 mm cv joint. It could be that the flanges and stub axles run a few mm's larger then the cv joints it self which is causing all of the confusion. So based on that I have 108 mm stubs and trans flanges then.
No such thing as a "110mm flange" it is a "flange for a 108mm CV with coarse splines".
You do have to watch out for the 108mm early flange (these are off of 1969 and earlier) and are for the weak diff with the tit bolts. They seem to bolt up but are dimensionality incorrect.
Half way down this page of Eric's post I tell you exactly what new CV's work and there are links to the bird with more info on CV's
http://www.914world.com/bbs2/index.php?sho...91963&st=20
