QUOTE(type47 @ Sep 2 2013, 03:08 PM)
QUOTE(914itis @ Sep 1 2013, 09:55 PM)
If you are looking for the original, they are no longer available new. You can put a WTB ( want to buy) in the classified, I have seen them going for anywhere between $150 and 600
You will need:
Throttle body
MPS
Intake runners
Injectors
Fuel rails
ECU
Distributor
Harness
intake air distributor/intake plenum
decel valve
Aux Air Regulator
air cleaner
Assuming this is a D-Jet system, you also will need:
Air filter
Air cleaner mounting bracket and hardware
Throttle body gasket
Throttle body return spring
Intake runner gaskets at air plenum
Intake runner gaskets at cyl head
TPS
Trigger points
Fuel pump
Fuel filter
Injector tip and body gaskets
Injector mounting brackets
Fuel hose, incl dealer-only adapter hose
Fuel hose clamps
Vacuum hoses
Fuel pressure regulator
TS1 - intake air temp sender
TS2 - cyl head temp sender
MPS mounting bracket
ECU mounting bracket
Tri-spade connector for grounds
Stacked elbow
90degree vacuum elbows
Charcoal filter
Misc assorted screws, nuts washers
..which is to say, be very careful when someone is selling an FI systems as 'complete". You need to know what every component is, whether or not it is serviceable and if every component above is included...or its not complete. If a given parts does not work, its worthless. No one pulls off a perfectly good, 100% complete FI system unless there is a problem with it somewhere. Be informed.
