Penelope is setup as follows:
Rear Suspension:- Koni gas adjustable Sport shocks
- 200# adjustable coil-over's
- 2 degrees negative camber both sides
No rear anti-sway bar. I suffer from terminal understeer on an AX course but the track and highway are both excellent so I don’t mess with it. To seriously AX I’d have to change a lot including swapping out the LSD box with a TBD box and different gears. This along with different spring rates mean I probably won’t ever do that… could build another car for that sort of thing.
- Elephant PolyBronze bushings
- 9x16 wheels w/245-45/16 tires
Front Suspension:- 1979 911-Turbo Bilstein Sport struts
- 23mm torsion bars (I figured out the spring-rate once years ago but don’t remember the outcome… seems like it was >350#’s)
- 22mm anti-sway bar (Tarrett)
- Elephant Racing PolyBronze swing-arm bushings
- 8 x 16 wheels w/ 225-50/16 tires
Good Luck!
