Ok to avoid the "screw won't come out" issue again, let me ask.....What is the object here? I am installing the long under the engine, curved shift shaft on my 75, side shift tranny. The coupling by the fire wall gives me no issues. However the one at the shift console does.
I assume you want to screw in the set screw until the shaft has NO PLAY, correct?
It ended up pretty tight, but I have no play. I guess it could it have wiggled around over the years and increased the size of the hole in the shaft.
Thoughts??
