root
Dec 12 2004, 09:20 AM
I just finished all the major work installing a front glass bumper from 'rennsport'
on my '72. Next is the rear. I'm going to attempt to post some pics.
Here goes.....
scotty914
Dec 12 2004, 09:22 AM
my first
spare time toys
wow its the stealth bumper I did not know those were for sale yet
root
Dec 12 2004, 09:23 AM
Hey, what did I do wrong?
root
Dec 12 2004, 09:24 AM
checking the fit
root
Dec 12 2004, 09:26 AM
bracket I added for bolting on permanent - 'till I crash!
root
Dec 12 2004, 09:27 AM
I also added a knife edge aligning plate on each side to the inside top edge.
root
Dec 12 2004, 09:28 AM
welded in the headlight web
root
Dec 12 2004, 09:30 AM
closeup up of welded web with bondo over the weld
root
Dec 12 2004, 09:32 AM
major work complete, with 'pilot' driving lights from 'camp914'
sgomes
Dec 12 2004, 11:42 AM
Outstanding job!!!
neo914-6
Dec 12 2004, 11:50 AM
Why bond it in? Won't it be a PITA to repair?
Felix
root
Dec 12 2004, 11:59 AM
Here's a corner shot. As far as repair goes. Sure it can be a pain if you look it
glass work that way. I like working with just about all materials, it's fun for me!
I just wanted to see how good a job I could do glassing the whole thing. If
I crack it or crash it I'll deal with it. I cutout the bumper below the driving lights
I can access them, what else do I do I need access to behind the bumper?
914werke
Dec 12 2004, 02:09 PM
Pretty clean
Where are your horns?
rhodyguy
Dec 12 2004, 04:34 PM
nice work. don't get your fingers caught in the headlights.
kevin
root
Dec 12 2004, 07:49 PM
I never really thought about getting my fingers caught in my headlights.
Do you suppose that was the reason for the original design having rubber
mounted webs in the front of the lights? I guess it could pinch you pretty bad.
Wonder if my old reflex's are fast enough? I got an idea!
rhodyguy
Dec 12 2004, 08:22 PM
HEY!!! i think i know those wheels.
kevin
michel richard
Dec 12 2004, 09:24 PM
The thing with the eyelashes was for any kind of material getting caught in there, fingers, or other stuff.
Michel Richard
root
Dec 12 2004, 09:58 PM
Kevin, I really like the wheels. I'm gonna miss them when I go to five lug.
Think maybe I'll stick with four lug, saw them in half, and weld in a spacer.
root
Feb 12 2005, 11:10 AM
fibermorphing flares
Tapped on sizing up!
root
Feb 12 2005, 11:12 AM
Marked for cutting -
root
Feb 12 2005, 11:13 AM
sheet metal screws holding it on prior to resin and fiber -
root
Feb 12 2005, 11:14 AM
overview before I begin the permanent install -
Air_Cooled_Nut
Feb 12 2005, 11:42 AM
I'm envious of your skills. She looks great so far!
root
Feb 12 2005, 07:38 PM
left flare-in-process....
2 lines: outer line is outer edge of flare, inner line is cut line.
I left the two bottom strips as they have the original fender well
support braces.
root
Feb 12 2005, 07:40 PM
15 sheet metal screws to register the flare alignment when the fiber and resin go on.
root
Feb 12 2005, 07:41 PM
left-side
root
Feb 12 2005, 07:42 PM
drilling a starter hole for the nibbler
root
Feb 12 2005, 07:43 PM
nibble time
root
Feb 12 2005, 07:45 PM
ready to grind off the paint around the edge
note the 2 bottom strips for support
root
Feb 12 2005, 07:46 PM
ground down to the metal
root
Feb 12 2005, 07:48 PM
resin - fiber - screws holding it 'till tomorrow after resin cures!
BahnBrenner914
Feb 13 2005, 02:13 AM
did you have to modify that front bumper much? I got one and it is a really bad fit. you have any suggestions?
neo914-6
Feb 13 2005, 11:10 AM
Dan,
Did you need to flare out the metal to match the f/g lip? Mine (Bills ex) were to match the HPH flares and they weren't bonded....
Are you going to add f/g mat/cloth on the inside?
Nice work and pics
root
Feb 13 2005, 09:36 PM
The above pic was taken after I coarse feathered the resin and fiber edges.
Next I fill the screw holes with putty and surfacce putty the edges and refeather.
Feb 13 2005, 09:45 PM
and when it's all done, she will look like this:
Feb 13 2005, 09:46 PM
rear also molded in ...
Feb 13 2005, 09:48 PM
btw. i also molded in the rockers ...
looks great, keep up the good work!
Andy
Aaron Cox
AAHHNDY
i like the look of the glassed in ducky.....
root
Feb 13 2005, 09:59 PM
SirAndy, I got a pic of yours and a couple others on my desktop!
To keep me motivated....
JohnB
Feb 14 2005, 11:13 AM
Nice work, the good weather we had the last few week ends must be helpful when you have to work outside here in the DC area. When you gonna put that thing back on the road?
JmuRiz
Feb 14 2005, 11:57 AM
Looks good, BTW where in Sterling are you, I'm in the woodstone area. Nice to see other local 914s that I don't know of. Maybe this car will be ready for Kerry's 914 picnic in Sept!
root
Yep! The weather is one of the main obstacles in control of the project.
Basically it goes like this;
Project Obstacle Priority List
1. Wife
2. Coaching Hockey
3. Weather
4. $$,$$$
Maybe ready for the road in July!
root
Feb 14 2005, 12:03 PM
Sterling is my R&D business location- just North of Dulles Airport 504 Shaw Road
....but I live in Chantilly. We work on cars (2 son's and I) at home in Chantilly as well as
in the machine shop at work in Sterling.
JmuRiz
Feb 14 2005, 01:50 PM
Ok, I know that area, been past there many a time, cutting through from Herndon parkway to 28, before the Old Ox/28 exit was done. Sometimes I use that bit as a test loop for my car, herndon parkway and sterling blvd.
scooter311
Feb 14 2005, 02:11 PM
Hey root looks great! Are you doing the fronts as well (maybe I missed that somewhere) and what color are you painting it?
Hey Andy I
your car
root
Feb 14 2005, 03:33 PM
Yep! Soon as I finish the rears, then I'll do the fronts.
Absolutely no idea about color..
I'm really becoming fond of primer grey
Wonder what clear coat would look like on top of primer?
Scott S
Feb 14 2005, 03:57 PM
Hi Root -
Mine was done the same way, except for the head light eye brows.....
Scott S
Feb 14 2005, 04:02 PM
... the funny part is that I cant wait until I have the time to bust them off with a hammer and go back to the normal fiberglass GT bumpers. The PO put them on my car.
