So I've been my 914 lately. It has been running well, as far as I can tell. I don't have anything to compare to except mine before the engine swap.
The main issue I'm having is the starter sometimes wont turn.
It has never been a problem before. The other day I tried to start it and no joy! I can hear the fuel pump working when the key is turned but no starter.
To test the starter, I removed the yellow wire from the terminal and jumped the (+)terminal to where the yellow wire was. It cranked!
I figure this means the starter is good. Re-attach the yellow wire and try it again.
Then it starts.
I have had to go through this a few times now. It happens when the engine is cold or hot. So I'm not thinking "hot start" issue.
It's pretty annoying to have to crawl under he car to jump the starter about half the time.
I'm now thinking there is a dead spot in the starter. Not convinced though.
I seek the wisdom of 914World (again). You got me this far.
What say y'all?
