So I have been researching what might be causing my oil leak and slow pressure build on start up.
Since the leak is coming from the oil pump cover I am leaning towards the idea that the pump is draining and takes a few seconds to refill and build pressure.
SO I can't remember if I used an o-ring when i installed the pump or not, but I have been reading in some threads that it doesn't use an o-ring.
If it doesn't how do I get it to stop leaking?
I used sealant and a gasket
