QUOTE(gunny @ Sep 4 2013, 05:39 PM)
I have installed wideband o2 sensor and gage. My readings are lean most of the time with everything connected. I disconnected the air temp sensor and adjusted my fuel pressure to 36 psi. Now at cruse I'm about 12.5 to 1. But it still goes into about 14 to1 when at about 4000 rpms cruse speed. I need my MPS adjusted. The MPS hold vacuum.
Should I adjust it myself or send it to someone for calibration?
I just went through this. It is not simple and helps to have a full understanding of the Bosch injection world of the 1970-s and 1960s. I just read an interesting article last night about the evolution of the system from the type 3 volkswagen to our type 4 systems.
I have no idea why you are running at 36 when the manual specifies I think 28 psi. I know that aircooled engines run cooler rich, but it is good to recall that stoichiometric is almost 15:1, so you have yet to report a truly lean value. I don't have the graph here, but how fast are you going when cruising at 4,000? Are you in top?
I have two thoughts. First, you haven't told us much about the engine, but if it is stock, I would run away from adjusting the mps unless there are signs that someone has already (un-) adjusted it already. They made them as best as can be for the engine and brain and they work great no matter what the gauges say.
Second, with all of that said, it may have a cracked diaphragm. I went in to start adjusting my MPS for a non-stock setup and bought a second MPS to rebuild. Reason? I wanted the stock MPS to fall back on. When I eventually took the stock MPS apart I found it was cracked even though it appeared to hold vacuum. Thanks to our racer Chris, these are available.
Good luck.
p.s. it helps to take notes along the way.
