QUOTE(Cap'n Krusty @ Sep 6 2013, 10:41 AM)
Lotta fuss over a readily available, and inexpensive, part. 901 424 229 00. Google it. Anywhere from under 3 bucks to a little over 6 bucks at Stoddard. Sometimes it's good to be a CSOB, other times it's pissin' in the wind.
The Cap'n
True enough. The problem is unless you want to stock them, you must order them and pay for shipping. Here in the Midwest that means California or Atlanta. A 10 minute lathe job works for me. I now just install a new 1/8" nylon ball in the old screw and reuse them. A pack of 100 balls costs less than 1 screw.
As far as not trusting a hand ground screw, you run into trouble if there is some movement between the hole and the screw cone. This can work loose. You also run the risk of damaging the hole making a new screw not fit correct.
