Hi! Long story short, I Greyhounded it to LA to pick up a 1974 fuel injected 2.0, had the clutch go out in the Mojave, then towed it with my Grandpa's help to Utah. A year or so later, it made it to its destination in Denver. I had no problem with mechanical fixes like dropping the transmission and installing a new clutch assembly, but the problem now is electrical, which is not so much in my scope of knowledge.
Facts:
The engine makes a weak attempt, but cannot turn over on its own; it needs jumping to go.
The engine can start and revs/idles well once jumped, producing some backfires occasionally (separate issue?).
Replaced battery, to no avail.
Meter shows continuity between positive and negative battery terminals, but not between the four red wires and the negative ground terminal.
Assumed initial diagnosis:
Battery is not the issue. Transmission Ground strap also not.
Alternator likely not the issue.
Key switch, fuses, and relay not the issue.
Problem is a short circuit/bad ground somewhere in the remaining electrical.
Questions:
Do these initial assumptions sound right? What is the best route towards pinpointing the problem?
Thank you for any insight and direction you may have!
