SKL1
Sep 8 2013, 06:02 PM
Want to refresh the transaxle. Have cleaned and cleaned the exterior but want to maybe paint it to make it look nearly new. Have seen various pix of trans painted with Eastwood paint but search wasn't helpful.
What have people used with decent results?
t collins
Sep 8 2013, 07:06 PM
I just went thru this a few days ago using Eastwood's Alumablast
euro911
Sep 8 2013, 10:09 PM
Rustoleum, gloss gray enamel. Easy to clean.
Click to view attachmentClick to view attachmentBlack is supposed to help shed heat better
timothy_nd28
Sep 8 2013, 10:14 PM
Hi temp ceramic engine rattle can spray paint is good. After the paint tacks up, throw it in the oven at 200 degrees for one hour.
PanelBilly
Sep 8 2013, 10:23 PM
I painted mine gloss black with exterior polane paint (I maybe spelling it wrong). Its a Sherwin Williams 2 part paint. I think I should have gone with a silver
John1180
Sep 8 2013, 10:48 PM
Krylon dull aluminum gives a great minimal finish that makes it easy to clean, for under five buck$!
maf914
Sep 9 2013, 06:41 AM
Besides cleaning off the heavy duty oil/dirt deposits, what should you do to prep the case for paint? The aluminum appears to be sort of porous and I would hate to see the paint peeling off after putting in the effort to apply it.
John1180
Sep 9 2013, 10:00 PM
Had mine media blasted.
Cap'n Krusty
Sep 9 2013, 10:01 PM
QUOTE(maf914 @ Sep 9 2013, 05:41 AM)
It's not aluminum, it's a magnesium alloy.
The Cap'n
worn
Sep 10 2013, 09:41 AM
QUOTE(SKL1 @ Sep 8 2013, 04:02 PM)
I used DP-40 epoxy covered with clear coat. The epoxy is tenacious and the magnesium was clean all around.
r_towle
Sep 10 2013, 08:07 PM
Gold? Really?
914forme
Sep 10 2013, 08:18 PM
Worn,
Nice looking engine. I have had issues in the past using brass fittings. Almost lost and engine due to the extension to get a VDO multiple oil pressure sensor way from the block. I now us a design by Draft 42 Design, that uses a hose and then a multi tapped adapter. its 8mm and has both 8mm and 1/4" ports.
Just giving you a heads up, hopefully you'll have better success.
Katmanken
Sep 11 2013, 05:20 PM
Designed a bunch of magnesium parts in m past, and the guy from the magnesium institute recommended an acid "pickle" to keep the parts from corroding, The books that he sent also recommeded a zinc coating as being a sacrificial anode.
Zinc chromate paint is one choice but that material is on the "hazardous material" and hard to find. It's also a little "soft" so I used a thin layer of a Dupont 2 part self etching primer (516S- 615s?) that contained zinc and sets up very hard . Then a thin coat of wheel silver.
914werke
Sep 11 2013, 06:09 PM
QUOTE(Cap'n Krusty @ Sep 9 2013, 09:01 PM)
The Cap'n
Really...?
not so sure,
if it is, its a
special "non-flammable" magnesium, since Ive had one go through as intense a fire as you can imagine and while the fan shroud DID burn up completely the trans while discolored was still intact and after cleaning & resealing it is operating in another car.
ThePaintedMan
Sep 11 2013, 06:15 PM
QUOTE(rdauenhauer @ Sep 11 2013, 08:09 PM)
Really...?
not so sure,
if it is, its a
Hence the term "alloy".
Katmanken
Sep 11 2013, 08:23 PM
The Cap'n
Really...?
not so sure,
if it is, its a
Really. Aluminum doesn't corrode (much) and magnesium does. Mag goes to an to ugly black color.
914werke
Sep 12 2013, 12:43 PM
Well wadd'a ya know....
Non-combustible magnesium alloys
Adding 2% of calcium (Ca) by mass to magnesium alloy AM60 results in the non-combustible magnesium alloy AMCa602. The higher oxidation reactivity of Ca causes a coat of calcium oxide to form before Mg ignites. The ignition temperature of the alloy is elevated by 200-300K. Oxygen-free atmosphere is not necessary for machining operations.
Dr Evil
Sep 12 2013, 01:36 PM
Dont media blast unless you have the whole thing apart and can clean it out very well. It will get into your bearings.
Yes it is mag, any paint that keeps it sealed is fine.
euro911
Sep 12 2013, 02:14 PM
I suggest that you DO NOT blast with glass bead. If any gets inside and stuck into a small nook or cranny somewhere, it WILL eventually work itself loose and into your lubrication. Unless you're 200% sure that you got it all out (goes for the engine case, heads, etc., too), glass bead WILL destroy internals very quickly.
worn
Sep 12 2013, 08:36 PM
QUOTE(914forme @ Sep 10 2013, 06:18 PM)
Worn,
I have the hose, but haven't installed yet. Thanks for the warning. It will actually simplify things.
Yes it is magnesium - the case is like a feather alone. Zinc chromate paint can be found at aircraft supplies.
The Dr is right you know. Dirt and grease is better than nothing because magnesium has a horrible jones for oxygen. Goes dull within minutes after brushing clean.
pete
Sep 13 2013, 09:39 AM
I did mine with POR15. So durable. Adhesion was great but might be yellowing slightly? Its been a couple years.
r_towle
Sep 13 2013, 04:51 PM
Is the Eastwood alumna last a paint specifically designed for this? Or is it just paint?
t collins
Sep 13 2013, 05:48 PM
QUOTE(r_towle @ Sep 13 2013, 03:51 PM)
Details
Spray-on a protective, durable, aluminum-look finish with AlumaBlast™ Paint AlumaBlast™ Paint is specially formulated to duplicate the original look of freshly cast aluminum car parts, such as intake manifolds and transmission housings. •Protects up to 300 degreesF
•Acrylic lacquer with low 4-15% gloss
•Aerosol can covers 6 sq. ft.
bulitt
Feb 10 2014, 02:40 PM
Just wanted to add this additional pic T Collins posted. Eastwood Aluma-blast. Very purty.
Phoenix-MN
Feb 11 2014, 08:26 AM
Hi-temp clear VHT engine paint on raw mag
OU8AVW
Feb 11 2014, 08:48 AM
Gibbs spray was recommended. Just a lubricant spray that shines the bare mag and brings out the marbling of the alloy.....Looks factory new
Nozzle
Feb 11 2014, 08:59 AM
QUOTE(Phoenix-MN @ Feb 11 2014, 09:26 AM)
Click to view attachmentVery nice! How did you prep for the case prior to VHT application?
Phoenix-MN
Feb 11 2014, 10:04 AM
QUOTE(Nozzle @ Feb 11 2014, 06:59 AM)
Hot tanked and media blasted it when it was dis-assembled for rebuilding.
ClayPerrine
Feb 11 2014, 10:14 AM
QUOTE(worn @ Sep 12 2013, 08:36 PM)
Worn,
I have had just the opposite experience. I had a hose running multiple senders blow out and spray oil all over the engine. Luckily it was in the garage at the time, so I was able to shut it off immediately.
I now have brass fittings, and I have never had any issue with them. I keep them as short as possible, and I support the senders with a bracket to minimize the vibration.
