Mikey914
Sep 9 2013, 01:21 AM
These are foil lined heavy felt, they reflect heat well and sound. They are foil faced on both sides. These can be glued in place or you can use Velcro. They are about 22oz in weight, a SIGNIFICANT weight reduction over the OEM. I had been making them from aircraft firewall material, but it's more fragile and more expensive. I do still make those, but for the dollar, these offer a good value.
Shipping would be less than $20 conus.
Who wants one?
TheCabinetmaker
Sep 9 2013, 10:36 AM
Mark, can you post a better pic? Having a hard time registering what I'm seeing.
Thanks.
malcolm2
Sep 9 2013, 10:44 AM
QUOTE(The Cabinetmaker @ Sep 9 2013, 11:36 AM)
Thanks.
Got one installed on a car? That would sell it!
Mikey914
Sep 10 2013, 10:53 AM
I will be installing this weekend.
Mikey914
Oct 6 2013, 01:19 PM
One month later, I finally got to it. But the wife helped. I really like the way this fit. The Velcro I used to install worked pretty well, had to have a second set of hands to help get it in. i have 7 of these left.
Mikey914
Oct 6 2013, 01:24 PM
Before
02loftsmoor
I've been told to leave the pad off it traps mosture. I have some rust were my old pad trapped water
Mikey914
Oct 6 2013, 01:27 PM
I added 2' of velcro. Not included, but I can add in for $12.
Mikey914
One more
Mikey914
Oct 6 2013, 01:30 PM
Don't forget to get this installed behind the metal strips that were used to hold in the OEM.
You probably don't need all the velcro, but I didn't want to glue it in, and I tend to overkill.
Kansas 914
Oct 6 2013, 01:51 PM
Hi Mark,
I am in for one with Velcro.
PM sent.
Mikey914
Oct 6 2013, 02:02 PM
QUOTE(02loftsmoor @ Oct 6 2013, 12:24 PM)
Yes I would normally agree, especially with the OEM. It's heavy and will easily trap moisture. These do not have the tar and if you can install to remove you can clean out behind and reinstall. That's what I did.
Mikey914
Oct 6 2013, 02:52 PM
