QUOTE(Jeffs9146 @ Sep 9 2013, 03:57 PM)
QUOTE(e_artiles @ Sep 9 2013, 03:52 PM)
I already removed the L/R targa pads and duct taped the rear glass so it doesn't fall in (already loose). I've also removed all of the screws holding the top targa pad but it's not breaking loose. Is there a secret or do I just pull harder? I don't want to tear this piece up!
Did you remove the screws and bolts on the rear top latches?
Seems there is a hard to get to screw near the latch as well. Maybe that was for the latch cover?
Did you remove the screws on the underside of the targa pad? Removing the “b” pillars should make it easier.
