Headlights, fog lights, front side marker lights and license plate lights are working correctly.
Other lights are a disaster. Here is what is going on:
Hazards don't work (new relay ordered).
Brake lights don't work - will be checking brake light switch behind pedal cluster tomorrow.
Front & Rear parking lights come on and stay on as soon as the key is turned (fronts are very dim).
When I use the right turn signal, this is what I see:
RF-right front
LF-left front
RR-right rear
LR-left rear
RF - operates normally
LF - has constant dim glow from driving light
RR - flashes, but brake/parking light flash when turn signal light cycles off
LR - no activity
When I apply the left turn signal, this is what happens:
RF - constant dim glow from driving light
LF - operates normally
RR - no activity
LR - flashes, but brake/parking light flash when turn signal light cycles off
Dropped the fuse block down and tested all the round relays.
Any suggestions on where to start?
