I've just rebuilt my first pair of Weber IDF carbs and it was quite an adventure. I probably could have bought a new pair after all the replacement bits I needed to hunt down and buy. Anyway, they're done except for the starter circuit, which I realize isn't part of the normal build.
My question is about blocking off the circuit. I've read on the Samba and 356 registry about procedures to drill and tap the holes for the starter valves and jets, but the best articles have dead links and no photos.
All I'm trying to find is if I even need to bother. None of the holes for the valves are jets are threaded. The bottoms of each tube seems like they were never machined for the circuit to begin with. Perhaps cast but not machined. I know that some, but not all, Webers need the modification for drilled, tapped, and screwed holes. Do my carbs need this procedure?
