QUOTE(jmargush @ Sep 11 2013, 12:33 PM)
When installing a type 1 oil pump in the type 4 do you use 2 gaskets (one between pump and case and one between pump and cover) or is there just supposed to be one between the pump and case?
I would use two, but others use permatex. The most important issues you may already know are alignment of the pump holes with the case holes. IME the pump needs to come away from the case a little with a spacer. Also the tang may need grinding to avoid cam gear interference. It needs to engage but not push hard.
