QUOTE(The Cabinetmaker @ Sep 13 2013, 08:12 PM)
Noel, that's a 73 or74. You will need to change every thing associated with them. That means muffler, muffler hanger, S tubes, J tubes, branch pipes, and lower tin pieces. Everything from the tail pipes to ( but not including) the flappers. That's a good thing. The late model system is very restrictive, and cost you a few ponies.
Ooops is that what it is? I was thinking of using the 74 muffler and heat exchanger but I did'nt know there is a difference on the other parts! In regards to muffler hanger, the picture of 4 the tips muffler from the 74 1.8 is not on a hanger and it looks very sturdy, so I was thinking the same. But as you said, other parts does not fit my 75 1.8.
Maybe for the meantime I will just remove the heat exchanger tin and just wrap the exhaust pipe with insulating header wrap.
Thanks a lot for the concern and God Bless!
