i finally had little time to check out oil leak in my 1975 1.7.
i initially thought i needed to replace my push rod seals to fix the leak.
a friend suggested to clean the bottom of engine and fill the oil and check 10 minutes to see if i can find where the leak is coming from. what i found is it is not the push rod seal but from top of the push rods. it looks like a cooling fin for the pistons. there is no black smoke when the engine is running. i am hoping it is not a blown piston or anything very serious. i usually top off the oil about 1 quart a week.
my friend thinks it might be from the oil cooler. what other parts that might leak on top of the push rods?
thanks guys
Click to view attachmentClick to view attachmentClick to view attachment
