I bought a 911 electronic speedo for my conversion that I really want to use. Initially I heard that it was compatible with the Subie VSS in the trans. Since then I have learned that the speedo is 8 pulses per revolution and the Subie is 4 pulses. Is there any way to correct this easily?
I found a couple of options but was hoping for something simpler, and of course CHEAPER :
Convert to GPS:
Livorsi Marine
A little pricey at $179
Universal Speedo Signal Interface
USSI
$84.95...probably the way to go...
Unless there is a simpler way I am not aware of? Just need to double the trans signal to 8X or halve the speedo output to 4X....easier said than done I'm sure.
