rhodyguy
Sep 13 2013, 10:01 AM
can't find what i think should be a 10mm in the tool box. before i buy one, is it a 10mm?
k
pilothyer
Sep 13 2013, 10:27 AM
QUOTE(rhodyguy @ Sep 13 2013, 11:01 AM)
k
8mm
r_towle
Sep 13 2013, 10:46 AM
8mm
rhodyguy
Sep 13 2013, 10:55 AM
thanks guys! my hex set that goes on a ratchet hits the cap before the hex meets the bolt.
k
r_towle
Sep 13 2013, 11:31 AM
harbor freight....
Get the metric long set...
rhodyguy
Sep 13 2013, 11:48 AM
nearest hf to me is 25 miles+ rt. i'm not paying for shipping!!
. i'll dig deeper in the tool box now that i know the correct size.
k
ldsgeek
Sep 13 2013, 12:14 PM
I'll probably get flamed for this but here goes. If you can't find the correct 8mm, a 5/16 is within 3 thousands of an inch and will usually work in a pinch. That being said, I heartily recommend you use the correct tool.
r_towle
Sep 13 2013, 04:22 PM
An Allen wrench works, no need for a socket.
And I have used American ones in a pinch...with a file to make them smaller when needed....
rhodyguy
Sep 13 2013, 06:03 PM
i know...
i get it
. too short.
REQUIRES socket(and a short extension so you don't wham your hand when the bolt gives way).
mrbubblehead
Sep 13 2013, 06:34 PM
mine were on SUPER tight on both cars. i wouldnt reccomend an american size allen. if it strips you might have a hell of a time getting it out. that cap screw is in an awkard place. i thought i was gonna either break the head off the bolt, my wratchet or socket. put a little dab of anti-seize on the threads when reinstalling em.
r_towle
Sep 13 2013, 07:40 PM
Allen wrench using the long end, then put the box end of a wrench over the short leg for leverage
