My favorite tire right now for all around god drive excellent wet is the General G-Max AS-03. Run them on a Miata, and a Jetta TDI. The TDI is highly modified and puts out close to 500 Fp of Torques. Great Wet weather grip!!! Dry they are not the best dry grip tire out there, as you can push them just past the edge, and they don't carry the stiffest side wall. Again, best wet tire I have used.
It comes in a 195/55-50.
Lifted off the Tire Rack Generals Kumho AST
Size................................195/55R15 225/50R15
Service Description...........85V SL 91H SL
UTQG..............................480 A A 400 A A
Load Max.........................1135 lbs. 1135 lbs.
Inflation Max....................51 psi 51 psi
Tread Depth.....................10/32" 10/32"
Tire Weight......................17 lbs. 21 lbs.
Rim Width Range...............5.5-7" 6-8"
Meas. Rim Width................6" 7"
Sect. Width........................7.9" 9.2"
Tread Width.......................6.5" No data present
Overall Diam.....................23.4" 23.9"
Revs Per Mile....................888 869 the 205/15-50s are 899
I ran the Kumho ASTs and hated them. Wore fast, great dry weather traction, would not stick in wet to save your soul. These where on a Nissian Sentra Spec V so higher power FWD car, which contributed to tire wear. And if you got in a little snow, forget it.
I have taken Generals through 4" of the white death with out issue. And I turn the traction control off on the Jetta in the snow and ice. If I needed tires on my new to me Subby they would be the Generals. Its a bargain of a tire, for the performance you get.
I wold also stay away from the Furzion's crappiest tire I have ever been on. Got them off a wrecked Jetta GLI, I think I know why he lost control and rolled the car off the highway. That was a sucky set of tires.
You also did not list the Dunlop's in your choices, they will wear fast, but a very good tire, much better than the Kumhos. On a 914 the tire wear should be like the Miata, no existent.
Doubt I helped you just trying to let you know my experiences. I drive a ton, so I get the benefit of trying lots of tires. My entire fleet rides on Generals right now.
