THanks! I remember seeing the cut-out pattern on the speaker box now. Last question, what is the best tool to use for cutting this out without damaging it? They are fiberglass.
QUOTE(biosurfer1 @ Sep 15 2013, 07:55 PM)
Yes, you'll need to cut out the speaker hole...the material is left there since different speakers have different sized openings. I would go get the speaker to make sure it's the right size, however you should be able to find the hole specs online if you know the size/brand of the speakers
