Looks good. Love mine and they are even better when driving and seeing the tach feed back. This is certainly an upgrade that is worth it!
Krieger
Sep 16 2013, 07:58 AM
Very nice! Depending on your mood you select the color?
76-914
Sep 16 2013, 08:11 AM
I like the "$" sign. Well placed!
timothy_nd28
Sep 16 2013, 08:17 AM
Looks good, now we need to do this same setup for the 914limo!
r_towle
Sep 16 2013, 09:31 AM
sweet..
I got mine in the car...just need to find the time to plug them in.
Aaaa dashboard...my least favorite thing to do on this car.
rich
914Timo
Sep 16 2013, 12:01 PM
QUOTE(76-914 @ Sep 16 2013, 04:11 PM)
I like that too !!
Sep 16 2013, 02:00 PM
I haven't driven it at night yet, but i did notice that i get a distracting reflection of the gauges on my windshield. Never really noticed this before but now that the gauges actually light up, it's right in my line of sight.
I'm guessing it's because of my 911 style dash. The little "hump" above the gauges is not deep enough to block all the gauge light.
monkeyboy
Sep 16 2013, 02:19 PM
Mine are definitely bright, but I don't get it on the windshield.
Try using the remote to dim them. I dropped mine down a bit to make them less noticeable.
Mblizzard
Sep 16 2013, 02:30 PM
Yes they are bright! I guess it is just so shocking when compared to the stock that you start to notice things like reelection. But the dim function on the remote should limit the reflection.
timothy_nd28
Sep 16 2013, 03:03 PM
So the light is being reflected from the back of the steering wheel towards the windshield? I'm not familiar with the getty dash setup, but could you add some spacers between the frame and the gauge holder for the top screws? This would change the angle slightly, and possibly fix the problem. Or, maybe paint the underside of this hump a flat black?
It's a odd problem, nevertheless a problem we should figure out before the car is driven.
Sep 16 2013, 05:37 PM
QUOTE(timothy_nd28 @ Sep 16 2013, 02:03 PM)
No. The light of the gauges goes straight up and hits the windshield at the same height as my eyes.
The Getty 911 dash has a similar hump over the gauges as the stock 914 dash to prevent just that but it looks like it's not going far enough towards the driver to block all the light.
I can see about 1/2 to 1/3 of the bottom of my gauges reflected on my windshield, right in my line of sight.
Mike Bellis
Sep 16 2013, 05:48 PM
QUOTE(SirAndy @ Sep 16 2013, 04:37 PM)
Get brighter headlights...
timothy_nd28
Sep 16 2013, 09:41 PM
Sounds like shoddy work, I'd send them back and demand a full refund!
Can you isolate which gauge is projecting light up?
JRust
Sep 16 2013, 09:50 PM
Yeah the getty dash doesn't have enough of a lip. You can either add a little something on the bottom side of the dash. Probably only need it to extend an inch or so
Sep 16 2013, 10:31 PM
QUOTE(JRust @ Sep 16 2013, 08:50 PM)
That's what i was thinking. A 1" strip along the top side of the hump should be enough ...
Maybe the 911 windshield is slanted differently? Or the dash is further back in a 911?
Black22
Sep 16 2013, 10:40 PM
See what happens when you put assdragger parts into our fine automobiles! You fuch up the design!
Sep 16 2013, 10:42 PM
QUOTE(Black22 @ Sep 16 2013, 09:40 PM)
Exactly ...
Black22
Sep 16 2013, 10:43 PM
timothy_nd28
Sep 16 2013, 11:03 PM
If somehow we can harness this unintended light shining on your windshield and funnel it into a Princess Leia hologram...
DBCooper
Sep 17 2013, 06:09 AM
His car is nicknamed "Princess Leia"? Well there's the problem right there.
worn
Sep 17 2013, 11:31 AM
QUOTE(timothy_nd28 @ Sep 16 2013, 09:03 PM)
I thought it was heads up display. Just look at it upside down.
Do you need to take apart the gauges?
ben*james
Oct 9 2013, 02:45 PM
Well?... did the dimmer work?
Oct 9 2013, 02:58 PM
I haven't had time to deal with the reflection yet. I drove it only twice at night since and it's pretty distracting even with the intensity turned down.
I just want to make clear that this has nothing to do with the quality of the LED light install. The problem is the design of the Getty 911 dash that allows the bottom 1/3 of the gauges to be reflected onto the windshield.
When i get the time, i will try an additional 1" lip above the gauges. That should be enough ...
ben*james
Oct 9 2013, 03:52 PM
QUOTE(SirAndy @ Oct 9 2013, 01:58 PM)
Agreed on the lights. It's not a product problem, it's an application issue. Thanks
timothy_nd28
Oct 9 2013, 04:26 PM
In your opinion, should this conversion be offered to the 911 types, or will they suffer the same problem you are having?
Oct 9 2013, 04:36 PM
QUOTE(timothy_nd28 @ Oct 9 2013, 03:26 PM)
Someone with a 911 should be able to tell you that for sure but if the 911 had the same problem people would have been complaining to Porsche about it for the last 50 years.
My guess is that one of the following is true:
- The 911 windshield has a different slant - The 911 dash is in a different location with regards to the windshield - The Getty 911 dash for the 914 has the cluster tilted forward too much
timothy_nd28
Oct 9 2013, 04:38 PM
I would really like to know the answer. Does anyone own a 911 on this site that is willing to let me mod their gauges? I'll do it for free
timothy_nd28
Oct 9 2013, 04:48 PM
This guinea pig/volunteer must have a type 2 clock. The type one's just don't come apart. Click to view attachment
ben*james
Oct 9 2013, 06:47 PM
r_towle
Oct 9 2013, 07:27 PM
Pick me, I have an 84 911 with stupid weak bulbs. I also have a new set of 914 gauges....as you know.
timothy_nd28
Oct 9 2013, 07:46 PM
If you have a type 2 clock, you're the winner, again
r_towle
Oct 9 2013, 07:49 PM
I have a clock....which works when it feels like it... Not sure what type
timothy_nd28
Oct 9 2013, 08:37 PM
Being that you have a 1984 model, I have a feeling that it can be disassembled. Just to be sure, yank the clock out and post a pic on here.
r_towle
Oct 10 2013, 08:18 PM
Will do
r_towle
Oct 11 2013, 11:49 AM
QUOTE(timothy_nd28 @ Oct 9 2013, 10:37 PM)
Stupid question. Is this just a grab, wiggle and pull thing to get the gauges out, or do I have to take out the faceplate and do some actual work?
Still driving her, actually heading out today for a fall foliage cruise....
Rich
timothy_nd28
Oct 11 2013, 01:59 PM
I'm not familiar with the 911 setup. There should only be 2 wires and a couple lamp sockets tethering it to the wiring harness. I imagine you should be able to pull just the clock out without any issues.
