you may want to consider buying the threaded perch at this point and moving into the 2.5 inch diameter springs.
These types of springs are much more readily available, and thus much cheaper, and with loads more spring rates.
Check this site...
http://www.colemanracing.com/Shock-Sleeve-...tein-P3700.aspxSo,
you get the threaded sleeve for your shock.
You get the small adjuster nut, same section of the site.
Get the top nut also...all of this is for the smaller spring diameter.
Then you go to the spring section and get the springs you want.
Rich
