Some of our 914 owner brethren have a personal hoarding addiction and this thread is an effort to help them fight and conquer this terrible disease.
Some 914 parts have little to no value and are effectively worthless. These parts include ‘date coded original factory’ worn out maintenance replacement parts that most people would just replace and toss out like used rubber brake hoses, used valve cover gaskets and torn weatherstripping, but some will keep even these – for bragging rights. But primarily, the worthless parts in this category rarely break, wear out or need replacement for any reason. This thread is about these orphan parts, and why a sane person should just toss them out because saving them thinking they will fund your child’s college education someday is futile.
In general, a worthless 914 part is any part that is broken, worn out to the extent nothing on it is useable or salvageable, is not repairable or can be used even partially to repair another broken part. Recycle it or toss it, but don’t keep paying rent for its airspace. Another characteritic of these parts is that there is no need to worry about finding these when you truly need them, because someone somwhere will always have these.
Or…Plan B, if you really think these are valuable, post a FPYPS: Free Parts You Pay Shipping ad in the classifieds and see how long you hold onto them.
Let’s make a list of them, which includes their mounting hardware – Its OK to toss these puppies:
Torsion bar end caps and adjusters
Front strut housings
Interior door latch cups
Door window posts
“Fasten seat belt” lamp housing
Severely dented, bent, cut/torn/drilled aluminum trim
Front trunk hinge arms
Rear trunk hinge arms
Front wheel bearing grease caps
Fuel expansion tank overflow tube
MPS brackets
Front windshield hoop ski rack cup
Front windshield hoop index block
Cracked, faded, chipped exterior lighting lenses
Rear window glass
Carpeting if worn out, stained frayed or otherwise damaged
Drivers side sunvisor with torn/missing map pocket
Passenger side sunvisor with torn/missing mirror flap
1975-76 heat exchangers and parts
1975-76 exhaust/muffler/catalytic converters
1975-76 rubber bumper covers
Fresh air system and parts
Engine bay sound deadening pad
Original Speakers
Headlight motors
Front trunk springs
Front suspension crossmember - steel
Inside rear firewall sound deadener
1.7 motor and related parts
Door interior panels with speaker cutouts
Doors with speaker cutouts
Front trunk hood
Rear trunk hood
Seats
Front A-arms (w/o the sway bar tabs)
Rear control arms
Shifter lever boots
Shifter lever knobs with cracks/chips
Rear trunk torsion bars
Windshield wiper reservoirs
What can you add to this list?
