jim_hoyland
Sep 18 2013, 05:27 PM
I made up the schematic of the Silver cube, a relay, and a yellow thing from what I could see.
This was installed 20+ years ago. I'm trying to understand how it works and whether I should replace it with a more compact module ie JWest
MartyYeoman
Sep 18 2013, 05:45 PM
What exactly does this setup let you do?
Marty
jim_hoyland
Sep 18 2013, 06:23 PM
QUOTE(Marty Yeoman @ Sep 18 2013, 04:45 PM)
Marty
It allows the fog lights to be flashed when the headlights are off. The Hi/Low beam stalk triggers the flashes, but the headlights must be off. When the lights are on, the stalk merely toggles between the hi and low beams...
Mblizzard
Sep 18 2013, 07:48 PM
Doesn't the
JWest wiring system do the same thing for $25?
904svo
Sep 18 2013, 09:03 PM
Jwest makes a unit that does that.
Check pelcan parts.
jim_hoyland
Sep 19 2013, 06:53 AM
QUOTE(904svo @ Sep 18 2013, 08:03 PM)
Check pelcan parts.
I understand the J West unit does the same thing, and will probably replace the existing parts with one; my question is diected at how the parts in my schematic work-especially the yellow thingy.
Tom
Sep 20 2013, 05:13 PM
Jim,
All three look like some type of relays. Without knowing the pin out information on each one, it would only be guessing how they work. looks like the middle one is switching around ground to the other two.
Tom
904svo
Sep 20 2013, 09:43 PM
I'm going to take a WAG the yellow relay is an old style flasher relay and the other
is a standard Hella relay. Which work on relay logic, that is one relay operates the
other relay then the 914 relays.
jim_hoyland
Sep 28 2013, 07:39 AM
Removed the old flasher circuit and installed the J West module yesterday. The headlights now work properly and the fog lights still flash.
The JWest module was easy to install with the clear instructions, plus, all the wires have the correct terminals for the installation. Took me all of 20 minutes to install including the removal of the old parts. Plus the module fits nicely into the fuse panel between the relays and the fuses.
