Hey guys,
I have a 75 1.8.
The engine seems to want to give out when I'm accelerating and especially when I come out of corners. RPM's do NOT drop. And at times the problem will come and go constantly while cruising, but slightly accelerating. The engine makes a "buurrrrrrr" sound when it does give out, but it'll kick back on in about a second. I can't get it to do this while parked and in neutral.
I pulled the throttle body thinking I had the throttle position switch with the potentiometer circuit that could get bent arms and bad connections. This one only has the switch for Idle to WOT. The throttle body was covered in oil which I assume came from the air hose from the oil filler neck. But I cleaned it up and still didn't seem to make a difference.
Any thoughts? Thanks.
