I've spent the past couple of weeks rebuilding a pair of Weber 44 IDF carbs (28mm chokes) with a set of recommended jets to make these large carbs work on a smaller engine.
I spent a lot of time with these carbs getting all new parts for the bodies - new bearings, screws, everything. I put them on the car and it started right up!
.... right up to 2300 rpm at 7 degrees BTDC set static with my fancy timing light. I can't actually get the idle down no matter what I do except for rotating the distributor, which I've also rebuilt stem to stern.
The idle speed screws are all the way out. The air corrector jets are all the way in. The throttle plates are super smooth and snap back nicely. The vacuum line is plugged.
Fuel pressure doesn't seem to be the issue either, given that it's a new CB Performance rotary 3.5 PSI pump. But I will order and install an inline gauge to verify.
I have also purchased synchrometer (STE). The carbs all seem to pull exactly the same vacuum (18-20).
The only way to get the idle down is to retard the timing, which arrives with a bonus exhaust backfire that my neighbors dislike. Something about ruining an outdoor dinner party or some such.
Help?
