1974 Porsche 914 2.0L; appearance group.
Color: Alaska Blue Metallic (original); average re-spray from previous owner.
Originally a CA car; moved to WA in 2005.
Mileage: 103k.
Newer KHUMO ECSTA tires.
Major maintenance performed by Redmond European; brakes/tune last year.
New Bosch injectors installed when purchased.
All gauges work except for the clock.
Rear sway bar installed.
Front oil cooler installed.
Rear glass re-sealed.
The longs are solid.
Car needs interior work/detail and exterior paint (surface rust and cracking).
The Fuchs could use polishing.
There is some rust in the battery tray; still holds the battery fine.
It runs/drives nice for a 40 year old car.
Shifts fine through all gears.
I would recommend a PPI from Redmond European if you are serious.
Price: $4,914; cash only.
