7TPorsh
Sep 23 2013, 10:55 AM
What's the tube size for the standard heat exchanger?
Trying to figure out exhaust options. thx
jimkelly
Sep 23 2013, 11:50 AM
I can tell you that a steel he 2.0 tube is about 41mm on the round pipe portion.
my guess is most OD's are about the same.
the ID on a steel he 1.7 is much smaller than the one pictured below.
jim
7TPorsh
Sep 23 2013, 12:15 PM
Since I have no heat and the back of my exchangers are rusted I am thinking of cutting the pipes just past the mounts and mounting resonators or mufflers on each side where the exchangers would be...then feed out the back. Thinking mufflers up front may quiet the VW sound.
Maybe dual inlet mufflers. But don;t know the tube diameter...1.25"? Anyone done this?
jimkelly
Sep 23 2013, 02:05 PM
how rusted you talking???
see this...
http://www.914world.com/bbs2/index.php?sho...=186693&hl=using manifolds from 1975/76 exhaust.
7TPorsh
Sep 23 2013, 02:15 PM
yeah something like that but feeding each cylinder into the muffler separate and the one tube from the muffler each side going out back.
7TPorsh
QUOTE(jimkelly @ Sep 23 2013, 01:05 PM)
see this...
I'd buy this in a heartbeat though....
jimkelly
Sep 23 2013, 02:25 PM
the problem - as I understand it - is you want some back pressure - and the system you are talking about won't have much BP.
if your muffler is good, you should seek out a decent set of 1.7 he's.
cheaper, easier, proper design for type4
barefoot
Sep 25 2013, 10:40 AM
QUOTE(7TPorsh @ Sep 23 2013, 04:15 PM)
see this...
Here's a different take on a similar system, mine's for sale as i want heat exchangers.
Other side i mirror image
Click to view attachment Barefoot
Charleston SC
jimkelly
Sep 25 2013, 12:08 PM
more weight means more weight hanging on the head exhaust studs.
I like the first dual set up better because the exhaust manifolds act almost like stub pipes.
jimkelly
Sep 25 2013, 12:09 PM
I like the first dual set up better because it is less weight.
though the two muffler set up may provide closer to stock back pressure?
gonna have to compare them on a DYNO
7TPorsh
Sep 25 2013, 04:38 PM
Are the stub pipes more/less/same restrictive as the older style? I like the first setup above.
With a turbo muffler on each side would it work for a 2.o dual carb car?
jimkelly
Sep 25 2013, 05:22 PM
with this late style manifold merging 2 exhaust ports into one so close to the engine, I have to say more restrictive, and the ID on this manifold is not much more than 1 tube on an old style.
that said, maybe firing order doesn't require all the flow old style offers????
IMHO, since these cars only pump out a whopping 80 or so HP, I doubt there would be much loss overall, but that said, I know RABY swears by THE TANGERINE header with its equal length tubes, etc.
but I am just talking out my ass. hopefully others chime in.
that said, I have a 1.7 and a 2.0 he set without tin in the classifieds. free + shipping for you.
cwpeden
Sep 25 2013, 05:31 PM
I've done this before on a carbed car and it sucked for tuning. As soon as I put stock 2.0 pipes and a old S&S header with quiet pack wayyy better.
When I get home tonight I'll post a pic.
I do know for a fact that I could fit the 1.7 exchanger tubes inside the Stainless 2.0 exchangers. as in OD of 1.7 was smaller than ID of SS 2.0's
jimkelly
Sep 25 2013, 05:51 PM
it is possible that a cross over pipe would solve the tuning problem - but who knows.
and whether or not ID has anything to do with tune-ability problems is also in question.
pls post a pic of the rust at the rear of your current HEs.
I can tell you that my - tin less - stainless 1.7 set weigh 13 lbs and my steel 2.0 set weighs 20 lbs. the difference when in hands, feels like more.
seems like staying stock is cheaper and faster and more predictable.
