I don't know if this has anything to do with that cut out problem or not, but I hope it does, but I'm guessing that the one wire that is loose from the connector, which may have gotten bumped, or something, wouldn't be there for no reason, if it were not to be put into that thingy??
It is a black wire that is just under the yellow wire on the right hand side of the electrical bracket. I have no idea what that particular wire's job is.
When I first noticed it, it made me think that it could be something that from vibration could have made contact off and on, as it was partially out.
I'm not exactly sure how those go in there, I assume there are little screws that hold them in?
I may have to take the maid body loose, in order to look in there to see?
