QUOTE(maf914 @ Dec 16 2004, 05:52 AM)
Is that by any chance Malaga red?
Bruce, How do you recommend mounting the front clips? Rivets or nuts and bolts? I ask because the fronts in my car were originally mounted with large rivets.
If they were rivited in someone replaced the bolts. There should be:
For the rears: 1- M6 X 35 bolt, 1- M6 nut and 2- A6 washers
Fronts: 2- M6 X 12 and 2- A6 washers
If the front nuts are missing you might have to get a slightly longer bolt to replace the stock bolt and add some nuts.
The official names for these parts are : Front- Bearing Bracket, Rear (isn't so techinal sounding)- Support for roof.
As to which colours (colors for Miles) are available :
Red, Black, Brown, Orange, Yellow, Green, Violet and Blue.
These are made with a dye which is added to the material when it is mixed and I can make them as dark or light as possible. I can't guarantee they will be exactly what someone wants, but I can try to make them as close as possible. Cost:add $2 per bracket and a picture of the colour from
Here would be helpful.
Before anyone asks, yellow ones are faster.
