QUOTE(doug_b_928 @ Sep 26 2013, 06:33 AM)
I reconnected the lines the same way they were connected (car ran fine when it was put into storage, so connections should be correct). If fuel flows to one line in the engine compartment without the pump even working (I assume this line is the one from the tank), would the reason for not having fuel in the return line be that the pump, despite turning, is not making enough pressure to force it through the rails and pressure regulator?
That was the point of the post. You need to get a FP gauge tied into the pressure side of the fuel circuit to see if it is producing the required pressure 28 lbs psig. I've used any pressure guage that would read 30 lbs ... even the one from one of those Harbor Freight 12 VDC tire inflators.
Since you didn't disturb the tank lines, I wouldn't think you would have a kinked supply line to the pump, but a kinked line can do the same thing ... starve the pump.
edit:
or the electrical connections to the pump are reversed causing it to run backwards.
