Hi. I just bought a 1974 1.8L and I have two small problems. First of all the brake handle came apart. The button popped out along with the spring and a little rubber washer. I lost the rubber washer but I'm guessing I can replace it with something similar. Once I get this washer, what do I need to do to get the button to stay on? Can I just put some glue in the hole that goes into the button and then just put it in the handle and hold it in until it dries?
The bigger problem with the emergency/parking brake is that I noticed the cable right where it connects to the end of the hand lever is broken at least halfway through. I'm guessing that this should be replaced as soon as possible. Is there a guide to replacing these cables?
Thanks in advance.
