QUOTE(Jeffs9146 @ Sep 27 2013, 05:28 PM)
Yea, just order the pads, unbolt the calipers, punch out the pins, squeeze the caliper pistons in, pull out the old pads, sand the new pads a little bit, slide in the new pads, replace the pins, bolt the calipers back on and pump the brakes! Done!
PS: Dont forget to clean up the brake fluid that overflows from the resevore when you squeezed the caliper pistons!
Do not try to squeeze the rear caliper pistons back in. They are on a screw to set venting clearance ... not self adjusting. Get a manual and read it about the rears.
I cheat and use a large screwdriver / pry tool on the fronts. While everyone says not to do it, I wedge the tool between the old pads and rotor and push to pistons back.
